Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 12-06-2005, 05:16 PM
bccrego bccrego is offline
94 lhs won't start
ran engine light code diognostic and came up with 12 43 55. need to know what the codes mean!
Old 12-06-2005, 05:49 PM
cj091184 cj091184 is offline
Re: 94 lhs won't start
12=battery has been disconected in the last 50 key on cycles
43=Peak primary circuit current not achieved within maximum dwell time (could be on ignition coil #1, #2 or #3)
the ignition coil on your car as stated above is 3 seperate coils, but it is actually 1 piece costs about $50. it is the plastic box that all of your spark plug wires run from. my guess is that it needs to be replaced. I recomend buying one and transfering the plug wires and the power wire from the old one to the new one but do not unbolt the old one, then see if the car starts before bolting on the new one that way you can return it if it is not the problem, but I honestly think that it is
55=end of codes
