Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-06-2005, 04:42 PM
zaknwfp zaknwfp is offline
catalyst efficiency below threshold, grand marquis 96
I had my grand marquis LS codes checked because the check engine light is continously on and engine runs at a little higher rpm than normal. The codes indicate that catalyst efficiency is below threshold. Does any one know where these catalyst efficiency sensors are located. Will cleaning these sensors help the check engine light go away?
Old 12-06-2005, 07:04 PM
come on guys.. somebody would know this one.
Old 12-06-2005, 07:14 PM
senior Citizen senior Citizen is offline
your link for a fix
http://www.obd-codes.com/trouble_cod...old-bank-1.php
Old 12-06-2005, 09:34 PM
lilvinny lilvinny is offline
You will need to replace the cat on side code is for.sensors are working fine they set the light to tell you cat isn't.
