Old 12-06-2005, 04:37 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Compression Question
Hey guys whats the normal comrepssion on a GSX engine ? Is 150 low ? What compression numbers am I suppost to look for ? Oh yeah , the engine is a 6 bolt turbo. Thanks
1997 Eclipse GSX
Old 12-06-2005, 07:57 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
180-180-180-180 is about right from what I can remember.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-06-2005, 09:31 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: Compression Question
arent turbo's generally lower compression? my talon is N/T and its 180 across the board
Old 12-06-2005, 10:00 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Are you getting 150 across? 150 is alright but there shouldn't be more than 10 psi variance between cylinders
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 12-06-2005, 10:36 PM
kjewer1 kjewer1 is offline
AF - Advisor
2G will typicaly be in the 175-185 range, and 1g will be in the 150-160 range. Compression ratios are 8.5 and 7.8 repsectively. There will also be some cam timing differences between turbo and NT which alo affect the cylinder test pressure.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
