obdII p0453
I own a 1998 sportage with the check engine light on obdII code as followed:P0453 Evaporative Control System Pressure Sensor High Input. I replaced the sensor on top of the fuel tank$$$$. I replaced the gas cap
and still the light is on. I unhooked the battery and it did go out, but just until I restarted it. I would be greatful for any help someone has. MURPH |
Re: obdII p0453
No personnal experience on that subject but checked with others to come with only these: check for any leaks on all hoses that come from hte evaporative TANK to the fuel tank. Someone talked about the electrically actuated valve on one of the hoses with corroded contacts (you see it on THIS diagram and HERE in the car
thus as I understand, not acting or staying open. And some said the alarm disseappeared as mysteriously as it came. Hope this can help.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. Last edited by LMP; 12-07-2005 at 10:41 AM. |
Re: obdII p0453
I have also seen the wire for the Canister close valve get smashed by the canister when oil change facilities remove the canister to change the oil filter. |
Re: obdII p0453
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Re: obdII p0453
thanks man ! it was really a great help !
Re: obdII p0453
It is possible the picture is from the SOHC and there might be slight difference. Anyway, check this one also
www.avigex.ca/z34/fuelcomponents.gif Notice you can register to www.kiatechinfo.com (it is free) and access full information to your vehicle manuals, diagrams, DTC...
