Old 12-06-2005, 02:42 PM
93tblx 93tblx is offline
Where is my fuel filter?????
I want to change my fuel filter. There's only one problem......I don't know where it is. Where is it?????
Old 12-06-2005, 02:48 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: Where is my fuel filter?????
on your firewall below your brake booster and a little towards the center of the car.
You have to remove your battery to change it.
Old 12-07-2005, 07:00 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
I've never pulled my battery to replace mine. Guess it might be a little easier to get at though. I want to give you a warning though. Do not remove the white plastic retainer clips unless you have new ones in hand. The old ones usually break when they come out. I remember stopping to help a guy once who was broke down in his Escort out in the middle of nowhere. He had, for some reason, decided to check his fuel filter. Both clips broke and he was stuck! Had to drive him 25 miles one-way to a parts house.
Nevada Tumbleweed
Old 12-08-2005, 11:44 AM
Re: Re: Where is my fuel filter?????
I'm a novice in automotive repair so what the heck is a brake booster and when you say center of the car you mean under the hood right???
Old 12-08-2005, 01:42 PM
Jet-Lee's Avatar
Banned
brake booster is the big black round thing connected to the thing you put your brake fluid in.
don't forget to shutoff your fuel inertia switch then run your car till it dies, then some, before you go pullin those clips. Otherwise, you risk getting a face full of gasoline.
Old 07-07-2006, 10:42 AM
quickywd01 quickywd01 is offline
I'm about to do this and wanted too. How does the filter come out, does it just slip out of the white plastic clips? And the fuel inertia switch, is that the fuel shut off in the trunk area? I was worried about having air in the fuel line, will this be a problem?
Nissan, Subi, Yoter, Ford
Old 07-07-2006, 12:30 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Don't worry about air in the line.
Use a small flat screwdriver to gently pry the clips out... I've replaced mine now and then over the 10 years I've had the car and never broke a clip. Yes, the inertia switch is in the trunk.
Old 07-09-2006, 12:40 AM
KimMG KimMG is offline
AF - Advisor
Try this link
http://www.autozone.com/servlet/UiBr...3d801560ad.jsp
Old 07-12-2006, 09:10 AM
mtmaurer8ooo mtmaurer8ooo is offline
There's a saying that goes something like - 'If you don't know what you're doing, then maybe you shouldn't be doing it'. Call a friend that know what's going on to help you though it or go to the library and check out a repair manual. The first time is always a learning experience and you will make mistakes. The good news is that it things get easier the more often you do them, but with cars the mistakes can cost a lot of money...or worse, they can cause you physical harm! MM.
"Listen to me Hillary. I'm not the first guy who fell in love with a woman that he met at a restaurant who turned out to be the daughter of a kidnapped scientist only to lose her to her childhood lover who she last saw on a deserted island who then turned out fifteen years later to be the leader of the French underground."
