1995 Blazer Questions
Hey all im new to the blazer world. i just got a 1995 black blazer Lt yesterday. it has some problems.
1. biggest problem is the tranny (i think) when driving cruising at 45 on the back roads and the rpms sitting about 2500 rpms you can see the rpm flucuating between a few hundred rpms like 2 or 300 it difficult to tell if its a slip because the rpm goes up and you can feel a pull like im tapping the gas. your head goes back not front like a slip... i dont get it... 2. when you first start it up it has a miss but only for a few minutes then its fine... i dont get that either... 3. the steering is horrible!!! it has horrible travel before its turns. im talkin 6 inches each way... im thinking steering box needs adjust ment does anyone know how to do that? when the wife gets home im going to check tie rods and steering box and stuff im hopeing its just the steering box. |
I can tell you from owning three blazers that they are known for idler arm wear, and ball joints. If your idler arm is bad dont replace it with a elcheepo part from autozone or advance auto. Go with MOOG chassis parts. Yes the ones from autozone and other places have lifetime warranty, but are they going to replace it everytime that part fails and pay for the 4 wheel allignment as well? NO! I did the autozone thing and twice a year it ate another idler arm. I put MOOG in (advice from my buddy that owns a garage) and have not had a problem in a year and a half. Good luck
1999 BLAZER ZR2 KENWOOD HEADUNIT KDC-415S KENWOOD PS-150 AMP JL AUDIO 10W6 BOSE SPEAKERS 6X9, 4X6 PARNELLI JONES DIRT GRIP 31 X 10.5 X 15 K&N FIPK COLD AIR INTAKE APC CARBON FIBER TAIL LIGHTS
Re: 1995 Blazer Questions
As for your other problems. When was the last time you done a tune-up? Plugs, Cap, Rotor, & Wire set? You also mite want to take a look at your EGR Valve. Make sure that you don't have any carbon chunks blocking the plunger. Clean it up and make sure the the plunger moves freely and closes all the way. Hope this help. Good Luck......... |
thanks man im going to do a complete tune up tomaro trans flush and oil change. service light was flashing then went steady book says its a missfire. i just got the blazer 2 days ago so i have no idea when any of that stuff was done....
i have this nasty smell... it smells like burning trans fluid... when i check it its full any one have any ideas? |
also the light went off after driving it for a couple blocks
Re: Re: 1995 Blazer Questions
yea im going to do it... i checked it its like dark like oil and smells bad.... but why would i smell it you think i have a leak?
Re: Re: Re: 1995 Blazer Questions
makes sense. you very knowledgable.. do you have all those blazers now?? my trans seem to shift slow between gears and this morning it slipped hard core into 3rd i had to let off the gas so it would shift. i heard the 4l60-e trans had alot of problem but i have no clue if this was every replcaed i never heard of one lasting 201756miles so i am guessing it had to be changed when i take it in for the trans service tomaro to my work do you think it will take care of the smell slip and slow shifting?? im hoping yes... |
Re: Re: Re: Re: 1995 Blazer Questions
Re: Re: Re: Re: Re: 1995 Blazer Questions
do you have a binding when you turn the wheel all they way to lock i only turned it to the left and it came from the front how do i know if it needs ball joints? i have alot of travel in the steering wheel b4 it actuall turns like 4 to 6 inches each way... any ideas? sorry for all the questions this is my first suv, 4x4 and first american car... im a honda person but my dad had a 97 lt and i loved it i learned on it so i sold one of my many cars and bought a 95 blazer lt. i want to keep this one for a while and want to learn about it and keep it running like new..... we bought it because all my hondas are hooked up= snow plows in the winter |
Re: Re: Re: Re: Re: Re: 1995 Blazer Questions
