Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 12-06-2005, 11:04 AM
EnergyForce EnergyForce is offline
Unusual Problems
Hi everyone, My question is that I have a 1993 Chrysler Lebaron LE and the rpm gauge radio and all non instuament panel lights are not working. Everything else works just fine and everything was working perfectly a few days ago the only diffrence between now and a few days ago is that I removed the light under the hood because it had burned out and that it is much colder now than it was before. Thank you for your responses.
Old 12-07-2005, 12:10 AM
94LebConv3La604 94LebConv3La604 is offline
Check your fuses?
Old 12-07-2005, 07:43 AM
I don't think its a fuse problem. I replaced the radio and gauges fuse with no effect. Ill check the internal lighting fuses when it gets warmer if it still doesnt work.
Old 12-08-2005, 08:46 AM
It sounds a lot like a possible fuse problem. Just give them all a check make sure they're sound. Whenever you get around to it.
Old 12-08-2005, 08:54 AM
k ill check them all when it gets warmer outside I dont want to risk breaking anything beacause its about 10 degrees outside right now brrrrrrrrrr thanks for the replies =)
Old 12-10-2005, 04:34 PM
Yup the problem was a fuse happened to be the dome light fuse replaced it with a nice new atc fuse and volla everything started working again. =) thanks for the suggesion
