Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 12-06-2005, 08:06 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
clutch
just wondering, whats the easiest (or best?) way to get the tranny to bolt back up to the engine (my car is a 89 240).
my friends and i tried using 2 jacks on the front and rear of the transmission, but it didnt help, since the trans kept tilting on one side and the bell housing would hit the bottom of the firewall, any suggestions?
RX-7 TII
Old 12-07-2005, 04:45 AM
nissan_240sx nissan_240sx is offline
Re: clutch
2 jacks are fine, i used them. hmm what kinda jacks did you use? the small ones or the big ones? (i used the big ones)
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 12-07-2005, 07:53 AM
atamotua atamotua is offline
Re: Re: clutch
use just one big jack in the very front of the transmission... and use your hands in the back of the transmission to control the angle.... you will need 2 people for this.... the guy in the back of the transmission who controls the angle of it and the guy in front of the transmission who helps guide the tranny into the clutch/flywheel/engine/guides....
Also, if you do have 2 jacks, or even if you don't, make sure that in some way you get the front of the engine lifted up as high as possible so that the engine tilts/angles UP in the front and obviously DOWN in the back so that you have a better angle for the tranny to slide towards the engine...
Old 12-07-2005, 04:59 PM
drftk1d's Avatar
Re: clutch
so i should loosen the motor mounts and tilt the engine?
can i get to the mounts from under the car?
RX-7 TII
Old 12-07-2005, 05:37 PM
Re: Re: clutch
*********************************8
Well, the engine on my car only tilts as much as the firewall lets it... when the top of the engine hits the firewall that's all you can tilt it.... i never had to loosen the motormounts at all... so just get it in maximum tilt position and try my instructions above...
another word of advice is, to bash in the firewall/sheetmetal a little bit, ... this is on the car, not the tranny (dont hit the tranny ok ? ;-) )... take a bigger, heavy hammer and bash the sheet metal especially around where the big bell housing of the transmission goes, and especially in the spot where the starter goes... this will give you an extra inch or so.... and the more room the better... always..
Old 12-08-2005, 01:21 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: clutch
cmon trannys arent that heavy just get a frient to help and its way easier with 2 people lifting than 2 jacks
do the tilting thing with the engine too, then when the tranny's on, jack the whole thing up and connect all mounts, then connect the driveshaft, shifter, and harnesses.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 12-08-2005, 07:51 PM
drftk1d's Avatar
Re: Re: clutch
youre missing the point, we had people lifting and we triend jacks as well
lifting it isnt the problem, getting it on the engine is
i know how to do a clutch, its just a pita on this car
RX-7 TII
Old 12-09-2005, 03:57 AM
Re: clutch
you mean the part about the input shaft meshing splines with the crank? just wobble it until it goes in...other than that i dont know what your talking about
Old 12-09-2005, 11:19 AM
drftk1d's Avatar
Re: clutch
dude, the tranny bellhousing is hitting the firewall when we push it up
RX-7 TII
Old 12-10-2005, 01:24 PM
Re: clutch
im assuming you have a cherry picker. if you dont, i feel sorry for you(read: go buy one). try having someone stand on the back of the motor. its so much easier when you can move the motor.
Old 12-13-2005, 02:26 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: clutch
Did you use the clutch alignment tool?
Old 12-13-2005, 09:52 PM
Re: clutch
good point, but that wont help the bellhousing clear the firewall...
