| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
primium fuel
quick question, in my car it says PRIMIUM FUEL ONLY, do i really need to use primium? what happens if i dont? (97 tsi turbo)
Re: primium fuel
you will detonate under boost. premium only
now - 2000 civic soon - 2002 is300
Re: primium fuel
you don't HAVE to if you drive it normally and never really get on the gas and boost, but if you boost any higher amount at all, i'd run premium. it lowers the flash point so you won't knock.
Re: primium fuel
Honestly how much do you stand to save by using regular? You risk damaging the engine for a couple cents per gallon.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
It's spelled PREMIUM.
You look at it every time you fill up. Shouldn't have a problem spelling it.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Re: primium fuel
Re: Re: primium fuel
haha what do you know he makes jokes
Re: Re: Re: primium fuel
to pay for premium is like $2 more on fill up, if you didnt run it empty (which you shouldnt ever come close to with a boosted engine) and also depends on where you live.
but then too you never want to run a diesel engine near empty. damn things fuel systems are like brake systems. |
Re: primium fuel
Man was I pissed, It just cut-off going up the bridge (no shoulder lanes either). Anyways, for next 2-3 weeks, car ran like absolute shit and the gas level readings where totaly off (needle would spas out).
Re: primium fuel
Thats crazy, I have run my Cavy out of gas 3 times, and each time after I got some gas in it, it fired right up and ran good. Why is it not good to run the gas down on a boosted car?
Re: primium fuel
You will run lean if you boost when REALLY low on gas before you run out completely
yeah i ran my saturn empty once and then i had fuel pump issues. gms typically have fuel pump/module issues. the module practically always acts weird, even new, but if you keep at least like 2.5 gallons in a tank you should be fine which takes getting use to when its at that level. i dont travel any lower then that in my car from now on. |
