Old 12-05-2005, 09:51 PM
bellz bellz is offline
starting trouble
Never had a problem with my 1998 Jeep
Jeep Cherokee until today. Started right up, and ran a
few minutes, but had to return to the house. When I
went back, it wouldn't turn over. No clicks, no noise
at all. Battery is good - just replaced 6 months ago.
Two hours later, fired right up. Turned the key off,
and wouldn't turn over again. Went through this
routine four times today. Any help would be
greatly appreciated! Thanks all -
Old 12-05-2005, 10:00 PM
fergmonster's Avatar
fergmonster fergmonster is offline
Send a message via MSN to fergmonster
Re: starting trouble
is it an automatic? if so.......Neutral safety switch.... jiggle the shifter.
Old 12-05-2005, 10:18 PM
Re: Re: starting trouble
Yes it is an automatic. I was just reading through the forum
and found the NSS on about page 10. Will try it in the a.m. - thanks so much for the input!
Old 12-06-2005, 03:29 PM
thebikedoctor33 thebikedoctor33 is offline
Send a message via AIM to thebikedoctor33
Re: Re: Re: starting trouble
i am having the same exact problem, full power, lights and all work fine, wont turn over at all. i tried putting it in neutral and starting it nothing, back into park nothing. i even slammed on the console a bit to see if that would help and again... nothing. i also put it in neutral and rolled it about 2 feet, put it in park and.... you guessed nothing. any suggestions????
and yes if you couldnt tell it is auto... and a 95 is that matters
