where to start?!?!
oook, just started this forum and ive been reading whatever i can but i cant seem to find what i need. ive got an 88 hf rex with a couple of problems so any help would be greatly appreciated. first off, when i got the car it didnt have an antenna, at all... so i bought one and tried to put it in but i cant seem to find where it comes through the a-pillar at and theres so much dang wiring in there i couldnt see even if it was, oh and im using the coat hanger method so if you know a better way, do tell. pictures would greatly help!!! second, ive got a blown headgasket, pretty sure of that and almost possitive it its cylnder to coolant cause it white smokes, theres oil in the radiator and it spits out "stuff" from the exhaust. does anybody know approximately how much it would be to get the hg replaced, ive already got the whole set just need it put on? and last but not least, ive got a brake light problem, ive taken out the fuse from the from the fuse box under the hood, but when i put it back in the brake lights come on and stay on no matter what. car is totaly off no key in it not touching the brakes or anything and the brake lights stay on. ive gotten under and looked at the sensor, its not broken but i havent checked to see if it was bad. also it doesnt even look like its touching the brake pedal at all is there a way to adjust it or the pedal so that it will make contact, its probably not more then an 1/16" gap. if that isnt the problem what else do you think it might be? oh and ive got just a basic question, does anybody know what kind of numbers you could get out of a built d15b6? sorry this was so long guys and thanks for the help in advance
