Old 12-05-2005, 07:09 PM
fishcrawl fishcrawl is offline
frozen newcomer with heating problems
93 grand am heater doesnt get hot (fan works and ac works) ....not sure how to tell if its the heater core or just the thermostat. Any help is appreciated, thanks.
Old 12-05-2005, 10:09 PM
mustang65 mustang65 is offline
Send a message via MSN to mustang65
Re: frozen newcomer with heating problems
reply: It sounds like the thermostat isn't closeing .If your temp gauge is staying low it's probably the thermostat.
Old 12-05-2005, 11:41 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
If the heat gauge is normal, I'd suspect a bad heater core. If the heat guage shows hot, and you have no heat, your low on coolant. And as mustang65 said, a low reading on the heat gauge indicates a stuck-open thermostat. Funny how a neglected cooling system will come back and bite you in the a$$ when you need it most..
Old 12-06-2005, 05:52 AM
it takes a while to get the temp up to about 160 and doesnt go above that
Old 12-06-2005, 06:15 AM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
It's your thermostat sticking open, a pretty easy job on a 93 regardless of which motor you have, just follow the upper radiator hose back to the motor, the thermostat is located under the water outlet. Make sure you use new gaskets.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 12-06-2005, 04:12 PM
thanks, I'll take a look at that. sounds easier than a heater core. (-5 degrees tomorrow)
