Old 12-05-2005, 07:00 PM
lank_dogg_420 lank_dogg_420 is offline
how to set timing on 95 4.3 W
im pretty sure that my timing is off and i want to reset it but i dont know how to do it.
Old 12-05-2005, 07:58 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: how to set timing on 95 4.3 W
I am pretty sure u can not set the timing on a 95 cpi 4.3. It is done by the computer automatically. u could on 94 and earlier and 96 and later but 95 is an odd year.
"because the reluctor wheel is an integral part of the crankshaft and the crankshaft position sensor is mounted in a fixed position, timing adjustment is not possible." that is right from the 95 s/t truck dealer service manual.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 12-05-2005, 10:12 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
96 and up are also locked distributors and cannot be timed manually.
That said there are 2 versions of the 95. If your ECM is under the hood on top of the coolant recovery tank (1st revision ODBII), then no, you cannot time it. (Ecm handles timing)
If your ECM is under the dash then yes, you can time it. Disconnect the brown or tan wire behind the passenger side carpet on the firewall. (this disconnects the distributor from the ECM)
Set motor to 0 degrees TDC, look at the crank pully, you will see 2 grooved marks on it. Use the one on the left to time with. When complete, reconnect the brown or tan wire behind the passenger side carpet.
Old 12-06-2005, 01:42 AM
OverBoardProject OverBoardProject is offline
Banned
This should be on the FAQ section
