Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 12-05-2005, 04:51 PM
Rick's69's Avatar
Rick's69 Rick's69 is offline
Send a message via AIM to Rick's69
009 distributer
What is so good about the 009 dist. ? should i buy one. i have the stock oon i think but it does not have the vacuum advance thing. also does a stinger ham the engine at all? i have straight headers to stinger and someone said the an exaust on headers is better for the engine. any help?
-Rick
Old 12-05-2005, 10:00 PM
BoatCop's Avatar
BoatCop BoatCop is offline
The .009 (centrifugal only) dizzy was originally designed for a static engine operation. On air compressors, generators, pumps, etc. that are best run at a steady RPM.
In 1971, when smog control was introduced, they were used as a cheap replacement for the vacuum dizzy. VW gear-heads discovered that they worked excellently on drag Bugs. That is, when they needed 2 speeds. Idle & WOT. They are very responsive when ramping up, needing no delay for vacuum.
Fledgling VW streetracers thought that if they are good enough for the pros, they must be good enough for their cars, too. And then they made their way onto ordinary street Bugs.
Therein lies the widely held belief that all VWs have an inherent "flat spot" or hesitation. Well, the .009 dizzy is what causes that hesitation. Especially when teamed up with the with larger carbs, such as the 34 PICT, or 44 IDAs.
Some interpret the hesitation as "power", but it's just the weights catching up with the engine to give a "burst" when the spark catches up. No more power than a smooth, no hesitation acceleration, from a stock distributor.
It's better to stick with a SVDA (Single Vacuum, Dual Advance) dizzy for general driving and smooth operation. A plus is the gain of about 4 MPG with the SVDA over the .009
As far as the exhaust system, check this page:
http://www.vwtrendsweb.com/tech/0109vwt_bolton/
for some tips and comparisons of VW exhaust systems.
Alan
BoatCop
Old 12-07-2005, 03:42 PM
Rick's69's Avatar
Re: 009 distributer
thank you
-Rick
