Old 12-05-2005, 03:59 PM
MS4ever8704 MS4ever8704 is offline
My 4x4 is not working properly
i just bought 2000 blazer LS i love it but when i put it in 4hi it dont engage & it kicks back to 2hi but when i put it into 4lo it works so if anyone have an idea please let me know hopefully its not that big of an issue
Old 12-05-2005, 09:16 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: My 4x4 is not working properly
The answer to this has been posted many times. (Use the search function)
Step 1: Pull the battery tray and look at the vac actuator. Check for tears or leaks. If found replace.
Step 2: Check your vac hoses leading from the actuator to the vac switch on top of the transfer case as well as the other 2 hoses leading to/from that switch. Check for dry rot and cracks. If found, replace.
Step 3: If the above is ok, then it will either be your vac switch on the transfer case or the encoder motor.
