Old 12-05-2005, 02:45 PM
dave4887 dave4887 is offline
coolant leaK
I have a 2002 grand am gt there seems to be coolant leaking from some sort of plug the plug is located on the top left side of the motor (if you are facing motor) it seems to screw into the motor and also has wires running to it ? any ideas I have pictures I took with digital cam but seems I cant down load to this sight
Old 12-05-2005, 02:53 PM
Re: coolant leaK
correction it is on the rightside not left
Old 12-05-2005, 02:57 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: coolant leaK
If the plug is on the drivers side of the engine, just below the thermostat housing, it's your coolant temperature switch leaking. There is a heater hose that has an o-ring that goes in just below that which could also be leaking and making the sensor appear to be leaking.
Old 12-05-2005, 03:06 PM
Re: coolant leaK
there is a hose running from the radiator to the same area but it is not leaking
Old 12-05-2005, 03:24 PM
richtazz's Avatar
Re: coolant leaK
yep, then you are talking about the coolant temp sensor. If the sensor somehow cracked and is leaking, you can get one at any auto parts store for about $15-$20.
Old 12-05-2005, 03:31 PM
Re: coolant leaK
can I just unscrew this without any problem
Old 12-05-2005, 03:50 PM
richtazz's Avatar
Re: coolant leaK
Have the new sensor ready to limit coolant loss (coolant will leak out when you remove it). After changing it out, take the car back to Auto-Zone/Advance and have them reset the code. The old "unhook the battery" trick doesn't work on 96-newer vehicles.
Old 12-05-2005, 04:46 PM
Re: coolant leaK
not getting any code
Old 12-06-2005, 05:50 AM
crys36 crys36 is offline
Send a message via AIM to crys36
Re: Re: coolant leaK
Could be a cracked intake. Happened to me..........
Old 12-06-2005, 12:56 PM
gmack221's Avatar
gmack221 gmack221 is offline
if im not mistaken it sounds like a 4 cylinder car, and since coolant doesn't run thru the intake on 4 cyl, thats probably not the problem. Sounds like either a temp senor or broken plastic water neck. Just what i gather from the facts given, giving motor size or # of cylinders always helps find the problem.
Old 12-06-2005, 04:05 PM
richtazz's Avatar
Re: coolant leaK
He mentioned the car was a GT, and most if not all GT's are V-6's
