Old 12-05-2005, 01:57 PM
Deadboy's Avatar
Deadboy Deadboy is offline
Send a message via MSN to Deadboy
Problem with friends hatch
My firend has a H/B 91 with a sunroof. He swaped hes D15 fo a D16 but he had problem with the injector wireing so he but his D15 carb on it and used D16 ecu not the D15 that he had before....car ran fine for a year...then the sunroof went out of order.......and then the rearlights started to do strange things.......we looked ower the thing and found out that if there is no power the rear lights work....if the ignition is turnd on the sunroof and wiper fuse is blown....and it blown loud...melts the 10A fuse.....is it a short?.....when we removed the upper connector behind the fusebox the wipers work and soo does the sunroof with the igniton on.....but he rear lights dont work ...soo is the short in there?.....and if so why does it blow the sunroof and wiper fuse?
Old 12-05-2005, 05:33 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Correct me if im wrong but dont only H/b SI's (d16 stock) have sunroofs? Sounds like short to power somewhere.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 12-05-2005, 08:37 PM
Hybrid1990crx's Avatar
Re: Problem with friend hatch
yeah i agree, sounds like a short to power. time to bust out the DMM and wiring diagram.
Old 12-06-2005, 01:26 AM
Deadboy's Avatar
Originally Posted by Jos4DCivic
Correct me if im wrong but dont only H/b SI's (d16 stock)...
He has 2 cars first is a D15 carbed with suneroof and then a wrecked D16 SI ..maybe the 1,5 is some euro trash Dont know...it had the sunroof when he got the car and it looks stock to me.
But the short is in the taillights? or with the sunroof or wipers wire? caz without the upper connector in the fusebox the sunroof and wipers work but not the taillights.
Old 12-06-2005, 07:54 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Sunroof and wipers are same circuit. Sounds like a problem in the fuse box itself from what you're saying or perhaps a crossed wire in the circuit. Like Hybrid said, time to bust out the wiring diagram... Go here and look at the "Electrical" section. GL
http://www.crxpower.net/~silverkorn/...hop_Manual.pdf
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 12-06-2005, 08:26 AM
Deadboy's Avatar
Re: Re: Problem with friend hatch
Ou 1 other thing ....he tried to change the fusebox to ....but nothing.....soo then we just have to start looking the diagramm and the wires that come from the wipers and sunroof
