Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-05-2005, 01:44 PM
dakotaman98 dakotaman98 is offline
what will i need to swap 3.9 for 5.2
please help me i need to know if the 318 will work and what do i have to do please halp
Old 12-05-2005, 03:31 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: what will i need to swap 3.9 for 5.2
You will need a donor truck of the same year (I assume 98) as yours. You will need the engine, transmission, all wiring harnesses and computer. You may also need to bring the Cat/exhaust setup from the donor P/U. The V8 Daks use a heavier duty (automatic or manual) transmission than the V6's is why you need the transmission.
Unless you can do all of the work yourself, it would be better to trade your V6 Dak for a V8 Dak.
Old 12-13-2005, 04:06 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
You need the engine, motor mounts, computer, shroud, and harness unless you splice into the old one.
My Mopars
