Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-05-2005, 01:11 PM
ericjoes ericjoes is offline
blower inop in cold
Hi all,
My fiancee has a 2000 saturn sl that has a blower motor that seems to not work on really cold days here in wi.. but works fine on days above 20... anyone have any ideas?? blower or maybe a switch/connector??
Old 12-05-2005, 05:58 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
is it in certain speeds, vent, defrost, ac, or is it not working at all in any of the settings? go through every combination and also listen for the blower. please, if you havent tried it all, go through it and come back with results.
Old 12-05-2005, 09:51 PM
LuckyRJ LuckyRJ is offline
my blower motor does something similar. On cold days, the heat coming from the vent blowing into the cabin work, but don't blow heat nearly as hard as they used to. This happened after a nasty cold day, I had no heat at all in the car... just cold air from any vent.
Old 12-06-2005, 07:21 AM
Re: blower inop in cold
no.. it doesn't change.. just barely blows at all on cold days.. those being under 30.... is the blower motor located behind the glovebox?
Old 12-06-2005, 09:24 AM
well it could be a failing motor. if there is snow on the outside vent it could cause the problem too. just one last question, does it blow the same with the recirculation on?
Old 12-06-2005, 10:24 AM
will have to try that... i do not know.... as for the vent.. there could be snow on it.. where is it located??
Old 12-06-2005, 12:13 PM
the black plastic piece where your windshield wipers are at. there should be vents there that allow air into the blower. its rare for that to happen but ive seen it happen before, so if it happens once it could always happen again.
