Old 12-05-2005, 12:00 PM
WReX WReX is offline
Wheel Bearings
need some help on changing the wheel bearings in a '94 SL, any tutorials or anything?
26 PSI anyone?
Old 12-05-2005, 01:24 PM
sugar3k sugar3k is offline
Re: Wheel Bearings
snowball needs help?
Old 12-05-2005, 05:01 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Wheel Bearings
front or rear wheel bearings?
if its the rear, its pretty simple. just jack it up (of course), remove the tire, remove the rotor. then you'll need to remove the axle nut holding the bearing in. i believe its a 36mm nut, but double check on that.
for a front wheel bearing, i think its pretty much the same procedure. there might be one other thing you have to remove, though. can't recall.
EDIT: oh, and obviously, to remove the rotor, you need to remove the brake calipers and all.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-05-2005, 05:10 PM
Re: Wheel Bearings
thanks for the reply, are these bearings pressed?
26 PSI anyone?
Old 12-05-2005, 05:11 PM
Re: Wheel Bearings
oh and its the bearings all around
26 PSI anyone?
Old 12-05-2005, 06:49 PM
MahdiVR-4 MahdiVR-4 is offline
Re: Wheel Bearings
I know mitsubishi dosent just sell the bearings, you have to buy the HUB assemly, and that's even easier since you just take out the whole thing. Their is 4 bolts i think that hold it and you just take those of and switch me out. Those bolts can be a big bitch do!! you will deft. need a air gun with this!!
Over here it was cheaper to get it at mitsubishi rather than orielly's. I was in hurry so i got it from dealer but u can always save some $ and order from either www.mitsupartdirect.com or www.ipsmotorsports.net (i think ips gives 26% off on all mitsu parts).
good luck
mahdi
1997 Mitsubishi 3000GT VR4 Twin Turbo SOLD
Greddy Profec B II boost controller set at 14psi, Greddy Turbo Timer, Stillen downpipe, Turbo XS RFL BOV, Walbro 341 Fuel Pump, intake, ACT Heavy Duty Street Clutch, AutoMeter boost and A/F gauge, AutoMeter gauge pod, Viper Alarm System, 15% Tint, 18x9 Saleen Wheelz, Bluethunder sparkplug wire.
best track time 13.068
www.goldenhomes.org -->
Old 12-05-2005, 06:58 PM
Re: Wheel Bearings
thanks a lot guys, the info. really helps
26 PSI anyone?
Old 12-05-2005, 07:01 PM
Re: Wheel Bearings
no problem, let me know if you have anyother questions. I think their was therad on 3si about how to swap the hub assembly (not sure do).
Mahdi
Old 12-06-2005, 01:53 AM
Linebckr49's Avatar
Re: Wheel Bearings
mahdi is right. the bearing comes in the hub assembly, which IS easier to install b/c you don't have to press the bearings in. but the nut shouldn't be that hard to remove. you can get it with a breaker bar or just regular socket wrench. the only problem is the size of the nut. as i said, i think its a 36mm nut. that's not a common size, but i think autozone carries a 36mm axle nut socket. its just about 10 bucks for that socket.
installation is a piece of cake.
93 3000GT base
Old 12-06-2005, 09:36 AM
JordanVR4 JordanVR4 is offline
Send a message via AIM to JordanVR4 Send a message via MSN to JordanVR4
Re: Wheel Bearings
Does anyone know how much a wheel bearing usuially costs?
Old 12-06-2005, 10:54 AM
Re: Re: Wheel Bearings
I think it was $98 from mitsu but i am sure u can get it for cheaper from www.mitsubpartdirect.com. I got it for both sides, only one side was bad but when side goes the other side goes right after that. SO might as well do it while you have the car up.
mahdi
Old 12-06-2005, 11:19 PM
Linebckr49's Avatar
Re: Wheel Bearings
i got one (right rear) for $40 at a salvage yard. (Chaparral Auto Parts--Frisco, TX).
you can most likely find one in great condition at a salvage yard. search www.car-part.com. its a database of salvage yards across the U.S. you can search by specific parts. great resource!
93 3000GT base
Old 12-07-2005, 09:46 AM
Re: Wheel Bearings
thanks for the advice. i will have to check that out.
