Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 12-05-2005, 10:31 AM
integrator97 integrator97 is offline
Pink oily fluid out exhaust
Warmed up my 2000 Trooper this morning, about 30 degrees outside. On the ground at the tailpipe, mixed with the condensation, was a pink oily residue. I've never seen this before.
Checked my oil, black and a 1/2 quart low. I use Mobil 1 Synthetic since about a month and a half. Uses a quart every 300 to 400 miles.
Any ideas?
Old 12-05-2005, 12:50 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Pink oily fluid out exhaust
Pink .... tranny fluid? But how would it come out the exhaust?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-05-2005, 01:54 PM
Hollowcreek Hollowcreek is offline
What color is your antifreeze?
Old 01-03-2007, 12:20 AM
79volaresw-owner 79volaresw-owner is offline
maybee a defective vaccum modulater check that and look for vaccuum lines on your tranny if any there should be no oil at all in them
crazy J.P here with my 79 volare stationwagon and a 93 saturn sc2 5speed with a broken tranny
Old 01-03-2007, 11:02 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Maybe Busted Trans Cooler Inside Of Radiator
Old 01-03-2007, 01:10 PM
trooperbc's Avatar
trooperbc trooperbc is offline
have you actually seen this 2eyefishclaw? (probably a silly question since you've probably seen it all with all your time working on things isuzu.)
but. . .if it is busted, how would the trans fluid get into the engine from the coolant? and how do those things get busted in there, just wear out?
EDIT ADD: just thought, wouldn't coolant then get in the trans? now that would be expensive mess!
thanks
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 01-03-2007, 11:13 PM
trooperbc's Avatar
integrator97 :: how's it running? any changes lately?
//bc
