Old 12-05-2005, 10:23 AM
gmyoyo gmyoyo is offline
Fuel pump voltage
I am trying to trace down a problem with my 95 s10 blazer. It shutters/jerks while accelarating and at cruise speeds.
The other day while trying to diag the problem I ended up stranded at the gas station. Just filled it up and it wouldn't start. Turned over fine but no start.
I know how to listen and even test for fuel pump so I ran those test and wasn't getting any sound. So, I tow it home, pull the pump, take it to replace and the guy hooks it to a battery and it fires... So, he replaces it with a new one anyway and sends me on my way.
I tested the voltage at the relay in the glove box and I'm getting 11.4x or close. I have not tested with the relay in place as I'm not sure how, do I go under the dash, is there some connector there that will be obvious?
I did test at the three pronge connector at the tank and I'm only getting about half of that. Say 6.3 or such.
If I hook the overide to the battery (small red wire under hood for fuel pump testing) I get the full 11.4x at the three pronge connector.
The new pump fires everytime now and the vehicle starts. But as I said I am still getting the stuttering/jerking feel when cruising or accel.
Am I looking at this right. Shouldn't I get a full voltage load via the Relay to the three pronge connection as I did with the override wire?
Do I just randomly test the voltage along the wire harness, and how, since it's all wrapped and insulated and such.
Old 12-06-2005, 08:53 AM
Re: Fuel pump voltage
Anyone know what the voltage reading at the connector on the gas tank should be?
Old 12-06-2005, 10:27 AM
Cailen Cailen is offline
Have you checked your fuel pressure at the shrader valve yet? Have you checked for a leaking fuel pressure regulator / nut kit? If not, pull your IMTV and have a look inside the intake for puddles of fuel / washing. It *should* be dirt black and carbony in there.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
