Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-03-2002, 05:27 PM
IntegraTypeRS IntegraTypeRS is offline
? about fuse box and dome light
okie i'm trying to install neon lights under my dash near the foot area.. i want it to light up everytime i open the door so i decided to hook it up to the dome light. well when i tried to hook it up to the green/darkgreen wire the neon would only light up if i close the door. well i don't want that. so i went to cut the other wire(the light pink and red) and right when i cut it(with the door opeN) there was a spark.. i cut the wire near the under the door foot panel.. anyways.. so i didn't think anything about the spark and proceed to hooking up the neon.. well it didn't work. and when i reconnect it back the way it was.. it didn't work either.. and now my dome light isn't work.. so i was wondering if that spark messed up a fuse? if so which fuse would that be? or is there a way to fix the dome light and connect it another way so i can have the neon light up everytime i up the door? thanks
95 Integra RS
Old 06-03-2002, 10:31 PM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
You probably blew your dome light fuse. Makes sense I would think.
Old 06-04-2002, 12:34 AM
do you know where i can get a diagram of the fuses?
95 Integra RS
Old 06-04-2002, 09:38 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
If i were you i would hook it up to the fuse for when you turn on the lights. The fuse is called, instrument lights, tail lights and somethin else i believe. The reason i say that is because you will only be able to see it when it's dark anyways...right? See what im saying? Let me know if you need any help with it.
95 Integra GS-R
[email protected]
Old 06-04-2002, 11:07 PM
i want to connect it to the dome light so everytime i open the door it will light up. but the thing is when i connect it to the door trigger it only lights up when i close the door..
when i fixed all the problems with my car imma retry it.
95 Integra RS
Old 06-06-2002, 05:07 PM
well i fixed everything.. thanks for your help i guess............... time to install my blue neons
95 Integra RS
Door light and dome light won't turn off Madstone Tercel 0 10-12-2007 12:34 AM
95 Blazer 4dr horn and dome light fuse blowing Lith1um Problem Diagnosis 1 06-05-2007 10:35 PM
Map light and dome light won't dim and shut off correctly. Efius Alero 1 07-29-2005 11:36 AM
Quick question about fuse box Josh_is1 Cherokee 7 04-07-2005 03:16 PM
Back-up Lights And dome light! GenieNChains Lumina 0 02-12-2005 07:35 PM
