1990 ford escort keeps stalling at junctions, idling speed erratic
My 1990 G reg 1.4 LX escort keeps stalling at junctions and the idle speed is very erratic, doesn't do this all the time, only when car seems to have warmed up. any ideas on what to check on car. Its a normal carburretor model I believe.
Check for vacuum leaks. Or maybe a bad EGR valve.
Nevada Tumbleweed |
Re: 1990 ford escort keeps stalling at junctions, idling speed erratic
i would also add some fuel injector/carberator cleaner.
Check the Positive Crancase Ventilation (PCV) valve. It could be causing the same symptoms. |
Re: Re: 1990 ford escort keeps stalling at junctions, idling speed erratic
Thanks, I have found out that a fuel cut-off solenoid on the side of the carb (right hand as you look at the car) has the wire missing from it, new part has been ordered but no-one seems to know where wire leads?
stall at stops
my 89 did the same it was the map sensor it tells computer its to rich or not rich enough when it stalls it dumps gas into engine and tells its self its running fine thats why the engine goes racing any part store has it
stall
its the map sensor mine did the same new map sensor problem is gone it tells computer when car needs gas or oxygen easy fix part 60.00 at part store
