Old 12-05-2005, 06:01 AM
quackmandude quackmandude is offline
Question single turbo, one manifold??
ok, on the whole single turbo deal, ive never asked if its better just to use one manifold of somehow use both. some ppl tell me that it wouldne be wise to just use one, but to some how use both, others say use one, fuck it. help, plz, thanks
'94 3kgt SL
-ebay intake (why not)
-2 1/2 inch straight pipe exaust, custom y downpipe
-Ignition mods
-dual magnaflow exaust
-going TT (wish me luck)
black book
-'95 mustang v6 (modded) /////
-'00 neon (modded/non-turbo) ///
-'04 eclipse GT
-'05 eclipse GT (modded)
-'97 Prelude vtec (modded)
-CRX (modded)
-Mazda Miata mx5 //
Old 12-05-2005, 07:49 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: single turbo, one manifold??
If you can build a single manifold that bolts to a v engine I congratulate you.
You can build it, but bolting it to the engine will be damn near impossible.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-05-2005, 03:54 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i think what you are asking is where you should locate your single turbo?
should you locate it after one manifold (using the exhaust gases just from a single manifold). OR should you locate the turbo after both manifolds, using exhaust gases from both banks of the engine to drive the turbo.
if you just use one manifold to drive the turbo, the setup will be much easiser. if you want to use both, then you'd have to locate the turbo in the downpipe somewhere, or do your own exhaust piping, which will be a bitch.
check out some people on 3si who have done the single turbo conversion and ask them(IPO, RBurnett) . i'd like to see where they located their turbo, and what kind of piping they did.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-05-2005, 04:11 PM
Putting a turbo on one bank and letting the other just flow is a very bad idea
Old 12-05-2005, 06:05 PM
MahdiVR-4 MahdiVR-4 is offline
The turbo is usally located right between the fues box (passenger side) and the raditor pipe. I don't think it would be worth hassel trying to do 1 header. Hell people can't even get their stuff runing right with their twin header single turbo setups.
go on 3si and their is bunch of pics and info on their. When i get home i will post up some pics.
good luck
mahdi
1997 Mitsubishi 3000GT VR4 Twin Turbo SOLD
Greddy Profec B II boost controller set at 14psi, Greddy Turbo Timer, Stillen downpipe, Turbo XS RFL BOV, Walbro 341 Fuel Pump, intake, ACT Heavy Duty Street Clutch, AutoMeter boost and A/F gauge, AutoMeter gauge pod, Viper Alarm System, 15% Tint, 18x9 Saleen Wheelz, Bluethunder sparkplug wire.
best track time 13.068
www.goldenhomes.org -->
Old 12-05-2005, 09:04 PM
Hotshot8792 Hotshot8792 is offline
most people who do a single turbo conversion put their turbo where madhi stated, in that vicinity. They make their own exhaust manifolds and exhaust outlet pipes. The exhaust manifolds come together before they go to the turbo. Seriously, from the results i have seen from single turbo 3/S's, your better off just using twins. A lot simpler, more available upgrades, and you don't have to custom fabircate anything.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 12-06-2005, 09:58 AM
yeah i agree, i looked into doing a single and nobody really has put down any power down, or not even got it running. You can almost just get a DR800 kit for the price your going to pay to build up a single kit.
mahdi
Old 12-06-2005, 11:18 AM
Re: Re: single turbo, one manifold??
mahdi
IPO ran 11's with his FWD single turbo car. There is a single turbo putting down something like 600-700 AWHP.
A used turbo off a diesel should flow enough. It holds 30psi to redline on my truck, it should do the same on this car. And they can be had for 2-300. Then just make your own piping and oil lines. I dont think it would be that bad expencive. I figure Ill try when I get some more money. Maybe hide the turbo where the AC compressor normally goes.
Old 12-06-2005, 06:46 PM
6g72tt 6g72tt is offline
I recommend you to check our the japanese cars in pit road M they have like 3 GTO's two are single turbo and AWD (97 and a 99), the 99 has 840hp and like 646 torque
Old 12-06-2005, 09:55 PM
Re: Re: Re: single turbo, one manifold??
yea, and then IPO switched to Twin 14B's and ran 10s.
Frankly, a big single turbo is definitely the better way to go on an inline engine, but twins seem to be more effecient on the V-6
Old 12-06-2005, 10:30 PM
Linebckr49's Avatar
Re: Re: Re: Re: single turbo, one manifold??
is it a matter of efficiency or rather design & efficiency as a result of design? an inline engine would have its exhaust manifold from all cylinders on oneside of the engine...ideal place fo the turbo. whereas a V-engine will have 2 manifolds, and thus the turbos would be one on each side. so it seems as if its more of a design matter.
93 3000GT base
Old 12-07-2005, 02:03 AM
so a twin.....hmmm what if i just put the single, and use both manifolds, cant i do that??? i could but it where the downpipe is right, i mean i aint no specailist in turbos or spelling for that matter, lol. but cant i get the same efficiantcy off a single turbo as i would an inline if i somehow used both manifolds. for one, it would spool a whole lot quicker, all i need is one side mount, and i could use a bigger turbo. but how would i do the headers???
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
Old 12-07-2005, 02:11 AM
Linebckr49's Avatar
that's what we've been saying. to fabricate the exhaust piping would be a pain in the ass and would cost more than doing a simple twin turbo conversion.
93 3000GT base
Old 12-07-2005, 03:51 AM
ok ok for a single turbo VR4 its logical that we are talking in fabricating a single turbo kit, and yeah maybe for 1/4 mile single turbos are a great option but for highway runs a single turbo upgrade would be the best even for a V6 engine just make a custom exhaust manifold and downpipe and your done
Old 12-07-2005, 04:30 AM
ok ok ok, i think i made up my mind, ima head towards the TT option, hell with it. but now what?? i got the list of parts and the FAQ from 3sx. now getting the parts??? any help here would be good, any vr4 tt parts for sale (turbos, manifolds, fuel pump, etc) or a donor car that someone has seen somewhere?
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
