Old 12-05-2005, 03:33 AM
oldchevy oldchevy is offline
cold idle slump until warm
I'm sure this has been covered a dozen times before, but now that it's cold again...
My 1991 C1500 4.3L cold idles (when started for the first time in the morning or after sitting a long time) high and fine, but when I put it into drive or reverse, it drops to almost a point of killing if i don't give it any gas. It does not kill, but takes a moment or two to get back up to proper idle. Once it's warm, everything is fine with no issues.
any ideas?
Old 12-09-2005, 03:46 AM
Re: cold idle slump until warm
no ideas from anyone about this?
Old 12-12-2005, 05:28 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Sounds like the Idle Air Control Valve is sticking, try cleaning or just replace it. Should be able to pick one up and any parts store.
Old 12-12-2005, 05:55 PM
roadrunner_70 roadrunner_70 is offline
Send a message via Yahoo to roadrunner_70
The fact that it runs fine warm might indicate a coolant temperature sensor problem.
Old 12-12-2005, 07:01 PM
do you have to drain the entire coolant system to replace the coolant temp sensor since its in the side of the block?
Old 12-13-2005, 03:19 AM
There are several ways to check it first, rather than just replace it. If you don't have a scan tool, you can check the resistance with a multimeter. I don't have the numbers in front of me, but can get them. Basically, what you're looking for is a change in resistance between a cold engine and a warm engine. Take the plug off when the engine's cold, and take a reading. Then, when the engine is warmed up, take the connector off again, and take another reading. Post the readings on here. If I don't have the numbers by then, someone else may have them. From what I recall, with the scan tool, the sensor reads -40 when cold.
Old 12-14-2005, 03:27 AM
i was going to test it the other day with my meter before i saw your post, but did not have time. I was noticing though that the only "switch" I see on mine is the a single lead "switch" coming out of the block on the driver side just above the exhaust manifold. Isn't there a difference between a temperature "sensor" and a temperature "switch"?
I thought the "temp sensor" was the one with two leads (signal and ground) and the "temp switch" is the single lead mounted by my manifold. I do not see the traditional "sensor" mounted near the thermostat area, only the single lead "switch" on the side of the block. How do I deal with that if I only have the single lead "switch" and no dual lead "sensor".
Old 12-14-2005, 02:03 PM
2000CAYukon 2000CAYukon is offline
Re: Re: cold idle slump until warm
The single wire "switch" in the cylinder head is for the guage. You should have a 2 wire sensor somewhere on the intake manifold which tells the ECM the engine temp.
//2000CAYukon
Old 12-14-2005, 10:08 PM
klt klt is offline
Re: Re: Re: cold idle slump until warm
I have a 4.3 Vortec in my Astro. I also have the temperature sensor mounted between the plugs on the drivers side. Manual indicates this sensor is used for the gage and the ECM. If you have a gage that indicates normal operating temperature, approx 195 degrees, the sensor is probably good. I have seen the 2 wire sensors mounted by the thermostat in the 5.0 and 5.7 V8 emgines.
