Old 12-05-2005, 01:09 AM
lank_dogg_420 lank_dogg_420 is offline
95 blazer runs and idles rough
i just replaced the CPI, cap, rotor, plugs, and wires, now it runs and idles kinda rough. the oil pressure goes down to about 18 when it is idling. the SES light is always flashing. i was thinkin it was maybe timing or the cat converter i pluged up from running with a leaky CPI
Old 12-05-2005, 01:29 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 95 blazer runs and idles rough
did you replace and check the nut kit?
Clean the EGR valve.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-05-2005, 12:28 PM
Re: Re: 95 blazer runs and idles rough
the nut kit looked just fine. i tried to clean the egr valve the best i could.
Old 12-05-2005, 12:39 PM
93LT 93LT is offline
When you inspected the nut kit, did you activate the fuel pump with the upper plenum off to see if those plastic lines were leaking (pin hole, non detectable by the naked eye)?
Pin had a hole that I couldn’t see even after seeing the fuel squirt from the line.
Rod
1995 K1500 Ext. Cab Stepside
1997 Olds Bravada AWD
2001 Silverado LT 2500HD CC 4WD
2001 Yukon SLT 4WD
Old 12-05-2005, 01:23 PM
i pressurize the fuel system many times to make sure that it was ok
Old 12-05-2005, 01:30 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
what about the fuel regulator?
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 12-05-2005, 01:55 PM
the fuel regulator is part of the CPI
Old 12-05-2005, 03:51 PM
BlazerLT's Avatar
AF -Advisor
I would recheck the EGR valve again, more carbon could have come loose.
Old 12-05-2005, 06:41 PM
i cleaned the EGR valve and started it up for a couple seconds with it off and a bunch of black crap came out but it still has the rough idle. i also hooked it up to a scanner and under I/M readiness the catalyst monitor, oxygen sensor monitor, oxygen heater sensor monitor, and EGR system monitor were all "inc". i also noticed that the fuel system would open and close at random. was also wondering if it could be timing when it runs shitty the advanceing goes from 8 to 26 degrees. when running somewhat shitty its right around 32 degrees.
Old 12-05-2005, 07:02 PM
scottb1 scottb1 is offline
I have a 94 jimmy with 183 k and it ran terrible @ any speed, also had fairly new cpi,clean egr etc. Just by pure luck, noticed the pink wire from igniton module to coil was chaffed and bare wire was rubbing on the distributer lock down bolt. ...good luck.
Old 12-05-2005, 07:25 PM
so i pulled the upper pleaum to see it it was the nut kit but what i found was gas sitting on the passenger side so i pulled the plugs and found cylinder 6 must be getting to much fuel cause the plug was soaked in gas. having just replaced the CPI i dont have and idea what is going on.
Old 12-05-2005, 10:31 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
It's not uncommon to get a bad CPI right out of the box. I would exchange it under warranty just to be on the safe side. Do a general tune up as well (cap/rotor/plugs/wires)
