Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-04-2005, 07:35 PM
racer77 racer77 is offline
Question i realy need help
i checked the oil on my 99 sL2 and there was none on the dipstick. that sucks.. i figured out that its burnin the oil because when i stop and sit for a while it will start to smoke out the muffler. and its burnin up fast . can anyone please help me figure out what needs to get fixed
Old 12-05-2005, 10:40 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
well normally on saturns it isnt an easy fix to get it to quit. saturns have issues with stuck piston rings causing oil to be burned. it could be caused by heat or, in my case, excessive fuel causing carbon build up on the rings. most people will take marvel mystery oil and pour enough down onto the piston that it pools. if you pour more then you will have to crank the car without the spark plugs in, or suction some out later. but let it sit for 24 hours if possible, if not try to let it soak for as long as possible min. of 20 hours or until piston is dry. if piston becomes dry quickly pour more on top of it. also buy new spark plugs, get some ac delco rapidfire plugs. those plugs are the only i have found so far that actually work. people always use ngk, but i used them and they did fine but they still didnt burn fuel anywhere as good as the ac delco rapidfire do.
the other problem it could be is leaking valve stem seals. the only way to fix this is to replace them. but with a consumption like that id say its the rings.
Old 12-05-2005, 09:04 PM
Re: i realy need help
thanks a lot, im gonna look into the rings . today someone told me they think its the valve guides . ill let u know what i figure out
