Go Back   Automotive Forums Car Chat > Geo > Storm
Old 12-04-2005, 11:11 AM
daily420 daily420 is offline
Send a message via AIM to daily420 Send a message via Yahoo to daily420
Angry car keep over heating help
[color=navy] this is what going on well the my car just started to over heat thought it was the raditor but there is no holes in my bf thinks it the water pump what else could it be please help 93 geo storm
Old 12-15-2005, 02:14 PM
dgee dgee is offline
Re: car keep over heating help
it could be thermostat or bad radiator cap a hose that collapsed fan belt loose. electric fan not working.
Old 02-26-2006, 11:36 PM
Light Storms Light Storms is offline
you don't sound confident in your diagnostic work, if theres no h20 coming from the bottom of the timing cover its probably not the h20 pump, if there is no water leak at all its one of three things thermostat stuck closed,head gasket , or electric fan not working, the "ghetto" solution is to remove thermostat , make sure fan works and simply drive it , if it stil overheats check for oil in water or water in oil or excessive oil or water in exhaust if you have any of those problem dont lose your head ha ha ok just shave your head adn use a new gasket and bolts any questions email me
Old 12-11-2007, 07:25 PM
Goatone Goatone is offline
My daughter has a 93 storm that kept overheating. Replaced the water pump and radiator cap and it still overheated. I finally checked the overflow tank and found that the intake area(where the radiator cap hose connects) had closed up and was not allowing any fluid in or out. I opened the hole and solved the problem. This may not be your problem, but it's an inexpensive check and fix.
