| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
Does anyone know where the thermostat is on a '98 Chevy Cavalier?
I had the water pump changed but it still overheats when I turn on the heater on my car. All I can think now is a hose (can't seem to find a leak) or the thermostat. Can anyone help? |
Re: Thermostat
The thermostat should either be at the water pump or at the housing at the engine end of the upper radiator hose. On my '97 it's stamped onto that housing that the thermostat is located at the waterpump IIRC.
Vinyl adds horsepower, right? |
Re: Thermostat
yeah.. just follow the upper rad. hose and it will lead u to the thermostat
www.cardomain.com/id/94caviguy Last edited by Chevalier; 12-07-2005 at 06:03 PM. |
Re: Thermostat
Thank you for your help. I got it changed. Now, lets hope that works to stop it from overheating when I turn on the heater again.
Re: Thermostat
good to hear...and hope it does..
www.cardomain.com/id/94caviguy |
Re: Thermostat
Sounds odd that the car overheats when you turn the heat on. A heater will decipitate heat from the engine. If the vehicle doesn't over heat if you don't turn the heat on, then this problem mystifies me. Sorry I couldn't be more help, this is the first I've ever heard of a situation like this.
95 Talon Tsi AWD 5spd 2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
