Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-04-2005, 04:54 AM
niwre niwre is offline
Send a message via Yahoo to niwre
Question wheel alignment
hi guys
ive just replaced my four tires, balanced properly together with the 4 wheel alignment. but as soon i accelarate till 100 km/h the car vibrates.
please advise?
and also they provided me with the specifications of the alignment done to my car. i would like to know if these are correct
left front tire right front wheel
camber= -0 degree 17 -0 degree 27
caster = 1 degee 20 1 degree 59
toe= 0 0
front total toe: 0
front steer aheed: 0
left rear tire right rear tire
camber= -0 degree 27 -0 degree fifty
toe = 0 degree 14 0 degree 14
rear total toe = 0 degree 29
rear thrust angle= 0 degree
car: camry 2000 4 cyl
Old 12-04-2005, 04:53 PM
AccordCodger AccordCodger is offline
Re: wheel alignment
Alignment doesn't fix vibration. (And bad alignment doesn't cause it).
Most likely cause is that you need your wheels balanced, despite the fact that you've just had it done. But there are other possibilities.
Old 12-11-2005, 07:07 AM
EA6BMECH's Avatar
EA6BMECH EA6BMECH is offline
Re: wheel alignment
Could be the brand of tires. I had some Douglas tires installed and all was well. Then the next set had noise to them and shaking all the time. Tire place said it was the rims warpped. That's alway the problem when the tires are bad....right?? Sheet!! So anyways down the road, the fronts wore and I got a set of Goodyears. Those things were worse....go figure!! Tire guys show me on the balancer that the rims are warpped as I watch the tire wobble on the balancer. I'm thinking how could they be bent if the car was fine the last time I had tires on it. Sooooo later, we're talking about a year later, I tell them to stick on a set of Michs and I want to see the tires on the balancer when they spin them. Well by gosh gally darn!!!! the rims all spun perfect!!!!! I asked them what did they do to staighten out my rims.....hmmmm dead silence from them!! So the moral of the story is, if you wheels seemed to be fine before, better get on the tire places ass. I'd tell you to go with the Michs. Wal-Mart sells them for about $88 a piece M&B with warranty!! Semetry it the name of them. As for alignments. I do my own. I look at the tire wear and tweak the tow per side. It only takes a small turn to make a big difference.
