Old 12-04-2005, 02:19 AM
phoenix696902 phoenix696902 is offline
need some serious help please
ok here we go , i have a 92 chevy 1500, the problem i am having is when my rpms drop my truck will shut off, try to restart and no gas to the injectors, but if i use some starting fluid it is fine but then stalls agin once my rpm drop, ....... changed my iac, tps, erg sol, map , all vac lines, top of throttle body, cleaned injectors, checked fuel lines no blockage, cleaned egr valve, pulled the top of the throttle body injectors and turned key to see if i have gas and it sprays all over ,,,,,,,,,,,,,,HELP ME PLZZZZZZZZZZZZZZZZZZ
i am really confused about this , will someone please help me on this ,,, also my engine is a 4.3
Old 12-04-2005, 05:09 AM
sreve sreve is offline
Question Re: need some serious help please
you did not mention check eng light on? any codes? runs fine otherwise just won't idle?
Old 12-04-2005, 05:20 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Have you checked fuel pressure or for injector pulse when this happens?
Lets do some basic diagnosis first before throwing parts at it.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-04-2005, 10:46 AM
rosty rosty is offline
Re: Re: need some serious help please
I agree If you didn't already have them you could have bought a fuel pressure gauge set up along with a set of noid lights and a multimeter with what you've spent already. One of these tools should lead you to results.
Old 12-12-2005, 01:03 PM
problem somewhat fixed
ok i did figure out somewhat what it is my ignition control module was shutting my injectors down but still have a small problem, it dont shut down anymore but when you tromp on the gas and let off quick it almost wants to die, my fuel pressure is good new fuel pump, new fuel pump relay, running soso better than not running at all
