Old 12-04-2005, 01:44 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
whine in differentials
While im driving im hearing a significant whining noise coming from the rear. The sound only occurs while im coasting with the transmission engaged around the 40-50 mph range. Otherwise there is no sound. How much should I worry about this thing dieing out on me? Im not hard on it at all. I cant hook worth a crap so it isnt getting a whole lot of stress. And as far as i know the posi function is working fine. Just when i let off the gas at around 40-50mph. If i push the gas back down the whine goes away.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 12-04-2005, 04:11 AM
runm-n-rekm runm-n-rekm is offline
97 Camaro differential whines too....
Hello 92zcamaroperson, My 97 does the same thing. I have the 3.8 auto with 120 K. Generally, I think this noise is nothing to worry about. It is the nature of the beast on a rear wheel drive car. I had a 318 '71 Plymouth that did this its whole life. That said, makes me want to check my lube and make sure it is full. Here's what my book says....
If the level is below the bottom of the filler plug hole, you'll need to add some lubricant. Add enough to raise the level to the bottom of the filler plug hole.
Standard Differential - use axle lubricant GM part #12345977 or SAE 80W-90 GL-5 gear lube.
Limited Slip Differential - To add lube when the level is low, use axle lube GM part #12345977. To completely refill after draining, add 4 ounces of Limited Slip Differential Lubricant Additive GM part # 1052358 then fill to the bottom of the filler plug hole with axle lube.
Or, just ask the guys at the oil change place to check the differential lube next time you get a change. As long as it isn't clunking and clanging I wouldn't worry. JJ
Old 12-04-2005, 05:08 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: whine in differentials
I wouldn't trust an oil change place with my differential oil. Then again, I plain out wouldn't trust an oil change place.
Change the oil, but the additive in, and see fi it goes away. That's what usually happens.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 12-04-2005, 07:27 AM
werd on the no lube place. But yeah i guess that would be the best thing to do. Any suggestions on what brand of diff fluid would you suggest? And then posi addidtive?
Old 12-04-2005, 08:05 AM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
mine does the same thing 92z at the exact same speeds and when i take off under light acceleration...i replaced the fluid with synthetic mobil and it still makes that sound....so iono
Old 12-04-2005, 08:30 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
You can tighten up the backlash a bit and that will usually take care of the noise.
All the whine noise is, is the clearance between the ring and pinion.
The noise will occur even if the backlash is in specs, but going on the tight end of the spec will eliminate the noise.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-04-2005, 01:32 PM
666_speed's Avatar
Son of Satan
Re: Re: whine in differentials
how exactly do you do that? thanks!
Old 12-04-2005, 09:59 PM
what he said. ?
Old 12-05-2005, 09:29 PM
lol on oil change places...
"I wouldn't trust an oil change place with my differential oil. Then again, I plain out wouldn't trust an oil change place."
Good call there Savage! I do trust my oil change guy though... good long time friend who has saved my rear on many occasions. Sharp eyes he has for stuff I wouldn't have ever noticed. JJ
Old 12-05-2005, 09:31 PM
666_speed's Avatar
Son of Satan
i have some 3.73's on order...will be better than the 3.08's i have now and ill just have it all fixed then by a shop
Old 12-07-2005, 09:15 AM
hey merlin. How do you go about the backlash tightening?
Old 12-07-2005, 10:36 AM
666_speed's Avatar
Son of Satan
i was told that you have to take the rear end apart to tighten the backlash...with that im just going to have a shop swap gears and be done
Old 12-07-2005, 11:51 AM
i want to put a girdle on it. Id like to find a decent set of street slicks so that I might hook once in a while. Im just afraid of tearing something up back there because the 10 bolt isnt supposed to be the most ideal for that.
Old 12-08-2005, 02:16 AM
BFG drag radials are my reccomendation
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 12-08-2005, 09:56 AM
do you think itll snap my rear? Or break my posi?
