Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 12-04-2005, 12:42 AM
NexTnmE NexTnmE is offline
Send a message via AIM to NexTnmE
Knocking from pass. side rear wheel-well
I've got a '92 lude s-type, no suspension mods yet. since september i've noticed a slight kocking, like a hollow plastic sounding knock, from the rear pass side wheel well (or close to it). since its gotten colder out its been getting louder. i took out my subs, jack, trunk lining, spare tire ect and it still does it! i put her up on jackstands to look at the shock, strut, a-arm and bushing and all, and it all seems tight, nothing loose at all. so i really dont know what it could be, maybe some molding on the inside by the rear seat? any help would be great...
Old 12-04-2005, 07:27 PM
Lockdown_2001's Avatar
Lockdown_2001 Lockdown_2001 is offline
Send a message via AIM to Lockdown_2001
imfamous shock knock question
Old 12-16-2005, 09:47 PM
absntmnd69's Avatar
absntmnd69 absntmnd69 is offline
Send a message via AIM to absntmnd69
i have a 93 si and i had the same problem but after i rotated my tires i had no problem......make sure to put the front passenger tire on the back driver side and vice versa
Old 12-29-2005, 04:59 PM
joellthomas joellthomas is offline
Re: Knocking from pass. side rear wheel-well
my 93si also does this. there is some info in an old thread about this condition, don't know if any one ever solved this noise. a loose wheel can do this also!!
absntmnd69(i have a 93 si and i had the same problem but after i rotated my tires i had no problem......make sure to put the front passenger tire on the back driver side and vice versa)
Old 12-29-2005, 06:14 PM
Zachp911's Avatar
Zachp911 Zachp911 is offline
Could be the cold weather taking effect on the bushings, they start to creek and pop when its really cold out.
2008 BMW 335i
Old 01-03-2006, 09:11 AM
AllmotorBB6 AllmotorBB6 is offline
try this:
http://www.superhonda.com/forum/showthread.php?t=248073
Old 01-03-2006, 06:01 PM
you're a savior man. thank you.
Old 01-07-2006, 12:34 AM
hell yeah! the shock collar worked like a dream! it was about a 25 minute job and now its perfect. thanks again for the help!
