Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 12-04-2005, 12:25 AM
3000gtdj 3000gtdj is offline
Question super charger or turbo
I currently own a 96 cobra with pistons and rods. I want more power should I go turbo or supercharger. I was also wodering should I get the heads and intake ported and polished, and if so does anyone know of a company that can do it. I also plan on buying bigger injectors, exhausts system, a new cold air intake, and a clutch and flywheel combo I want to make about 600hp.
Old 12-04-2005, 02:08 AM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Re: super charger or turbo
im pretty sure on high tq engines a good SC is actually more efficient than a turbo. i forget where i read that though.
Old 12-04-2005, 03:16 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Re: super charger or turbo
Hold on there.....
Never will a SC be more efficient than a turbo, never ever!
If you want that much power, its either going to be a T-trim Vortech pushing out a good 18lbs, or you can go with a T-70 or T-76. Turbos are a little more expensive, and a little harder to install, but you will always get more power out of a turbo...point blank!
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 12-04-2005, 03:43 AM
TheStang00's Avatar
^^ thats what ive always thought to but recently i remember reading something on how on engines like v8s good superchargers can actually have less parasitic loss than a turbo does from back pressure. i could very easily be wrong though
Old 12-04-2005, 04:15 AM
SkylineUSA's Avatar
Its just physics, not sure where you read that, but it simply not going to happen, unless you have a complete miss match, but who in there right mind would want to set up an engine with a miss matched turbo?
Old 12-05-2005, 12:37 AM
mr_tw's Avatar
mr_tw mr_tw is offline
Superchargers are nice, but I tend to favor the turbo myself, especally when ou want a specific amount of power as opposed to "I want to run about 18lbs of boost" because you can run a turbo at less boost to achive the same horse power and therefore save some reliability, also a turbo saves you gas (especally on the highway) and assuming you keep your foot out of it, compaired to a supercharger, because the power lost to backpressure is allot less than the power lost to turning a pump via a belt, true lag is a problem, but i was once told that some people call it lag, and others call it giving your opponent a chance lol but also lag it completely dependant on the turbo you choose, and many other varables but whatever you choose, good luck!
What Is With The Hatred Between Imports and Domestics? In The End, We All Love Cars.
Old 12-05-2005, 09:08 AM
01L2Cobra's Avatar
01L2Cobra 01L2Cobra is offline
Go with a turbo. You should get the heads ported and new cams while you have them out being worked on. I would also look in to a different intake instead of doing work on your stock one if you have the money. The FR500 intake is the best there is for the DOHC cobras however it is $3k+. 4.6 Cobras breathe about as well as a 5 year old with a cold. You should also look in to forged internal while you are doing all of this work since the stock Ford internals are crap.
The ///M stands for Motorsports
Old 12-05-2005, 11:59 AM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
id go with a SC
Old 12-05-2005, 12:33 PM
mr_tw's Avatar
when you replaced your pistons and rods, what did you upgrade them with? are they forged, and what compression ratio are they? when going with FI (as i'm sure you know) you will want to have your compression ratio around 8.5 depeding on the gas you have (we are stuck with 91 where i live) and what internals you have as well
Old 12-05-2005, 07:19 PM
The pistons and rods are forged. I forgot the compression ration but they are under 9.0
I've decided to run a single turbo setup, but I'm not sure of what size to get, will a T-44 turbo be a good size or do I need to get a T-61 or T-64.
Old 12-06-2005, 12:38 AM
SkylineUSA's Avatar
If your gonna go turbo, go to www.turbomustangs.com and read. You might want to buy a couple of books and read up on how it all works, so you can make an informed decision.
Old 12-06-2005, 11:16 AM
mr_tw's Avatar
i agree with Skyline, you can never know too much when doing somthing like this, it's when you know too little that somthing breaks
Old 12-06-2005, 09:26 PM
mr_tw's Avatar
whats the MAF rated upto on the mustang, I think i read somwhere that it's only good to about 500hp, but that could be bad information as well
Old 12-07-2005, 12:11 AM
SkylineUSA's Avatar
What do you mean, what is a stock MAF good too?
Old 12-07-2005, 05:19 PM
mr_tw's Avatar
I'm Fairly sure that the STock Mass air flow sensor maxes out at about 500 hp, but i could be wrong about that, does anyone know anything about this?
