Old 12-04-2005, 12:06 AM
4G63t Power 4G63t Power is offline
Slowboys Act 2600
The stocker is no longer liking the power and is starting to slip. Looking on sbr's site they have 15% off Act's cluctches right now. Question is... They sell a 4 puck, 6puck, and street disc. What is the difference... good and bad of each... Let me know, Thanks
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 12-04-2005, 04:50 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Slowboys Act 2600
Puck clutches are really only good for race cars. With extended use they are famous for taking the splines of input shafts, snapping input shafts, and other expensive damage. Many poeple install a pucked clutch and shoot gears out the side of the case within a week, especially unsprung units.
All that being said, I highly recomend a street disc for anything under 500 whp and reasonable weight. Over that and you may need to start taking some drivetrain risks to keep holding the power, or just go up further on clamping force to the 2900 or 3200. Actually, with FWD, you can be a little more sure that a 2600 with a street disc is all you will need, since the tires will let go before the clutch starts to slip.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-04-2005, 01:23 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
I could be wrong but you describe you had your head shaved. Usually shaving head means higher compression. But on are turbo cars lower the compression means better for more boost, which means buying a thicker head gasket and not shaving the head.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
