Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-03-2005, 11:05 PM
nick bamberger nick bamberger is offline
Squeaky Struts
About 15,000 miles ago(180,000), I had Sears replace my stock struts, with a set of monroe sensa-trac struts.
Now,at 196,000, I have noticed the struts in the rear have started to sqeak. They still ride firm, but the sqeak is annoyoing.
Is their anything I can do to stop the sqeaking, other than replace them?BTW-just started sqeaking when weather became cold. THANKS IN ADVANCE!
Old 12-04-2005, 08:16 AM
Joe W Joe W is offline
Re: Squeaky Struts
Check the stabilizer bushings. (Cheap & easy!!)
Old 12-04-2005, 11:05 AM
Re: Squeaky Struts
Stabilizer bushings are the same as sway bar bushings, Right?
I've already replaced those, if so. Sway bar bushings made a chunking sound, so i replaced them about 20,000 miles back. If these are the same thing, thats not the problem.
But thanks for trying, Joe W.
Old 12-04-2005, 02:36 PM
norm21 norm21 is offline
Re: Squeaky Struts
Remove yor wheel, try to reach the polymer damper that surrounding the strut's shaft. Once you find it try to move down that polymer part. I found in the past, some rubber coming from the rubber boots surronding the struts. Of course the spring migt be in your way but this is feasible.
If your rear suspension is making some loose noise when you hit some bumps, check your sway bar, this bar can br loose on the rubber grommets. By installing some electrical tape to beffed up the diametre of the bar at the grommet location. That worked pretty well.
