Old 12-03-2005, 10:43 PM
allstar323 allstar323 is offline
weird fan problem
So my car was sent in for a tune up...It's got 257,000+ miles on it, but I'm sure that is irrelevant. After the tune up, the first (lowest) setting fan speed does not work...The other three do. If the AC switch is on, the compressor turns on, but there is nothing coming out of the vents. Recycle-air is on, and the top vents are selected. Is there a way to fix this?
Old 12-04-2005, 08:47 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: weird fan problem
mine is the same way too, the 1st speed doesnt work, all the rest work fine
Team Lonely Drivers
Old 12-04-2005, 11:06 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
You both need a new(er) fan speed resistor. The fine wire for the lowest fan speed has burned out (much like a bulb filament). It's located behind the glove box held to the heater box by two screws. You can either get a new one from the dealer or forage at the junkyard. The same resistor is used for several different Hondas and Acuras. GL
