Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-03-2005, 09:05 PM
rajeevesaini rajeevesaini is offline
Cool 91 Bonneville thick white smoke on startup
My car gives out thick white smoke with a sweetish odor, for about 5 minutes after startup; after that it goes back to normal. Anybody know why? Also, the windshield is cracked; could I replace it myself or should I take to the dealership? Appreciate any advice, thanks!
Old 12-04-2005, 08:33 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 91 Bonneville thick white smoke on startup
You either have a leaking manifold gasket or head gasket. It is leaking when the car is cold and getting in to the cylinders that is why you get the thick white smoke that smells sweet on start-up. You really need to get this checked by a mechanic before you ruin the engine.
As for the windshield, don't try to change it yourself, leave the installation to a professional otherwise you could get leaks or break it when you are trying to install it.
Old 12-04-2005, 03:42 PM
Re: Re: 91 Bonneville thick white smoke on startup
Thanks, GTP Dad; will do.
