2000 LeSabre- no power to diagnostic port
the title pretty much covers it. DEQ says the port has no power so it can't pass emission test. apparently the scanner acts as if it isn't even hooked to a car.
Re: 2000 LeSabre- no power to diagnostic port
I don't know why you don't have power at yourdiagnostic port...but here is a layout of the port I found on the interne. It's at this site: http://obddiagnostics.com/DataSheet.pdf Regards Dan |
If you have the voltage, then you have a Class 2 communication problem. You probably have a body or chassis module pulling down the line where each module would have to be disconnected to isolate the faulty module. |
Re: Re: 2000 LeSabre- no power to diagnostic port
someone had removed the fuse. thanks |
Re: Re: Re: 2000 LeSabre- no power to diagnostic port
Here is the 1000.00 question....Why would someone remove that fuse? ?? Did other items come on when you replaced the fuse? Regards Dan |
