Obdi...
I'm going to buy a used integra... what year did they start using OBDII? OBDI is better for tuning, right? I was thinking of getting an LS with over 100K miles (cheap) then swapping a GSR engine+a mild turbo setup (6-9psi). Am I glutton for punishment with a car that old, or with a new engine should the rest last? Also, would the OBDI LS ECU work for Hondata, or would I need a GSR ECU?
thanks in advance! |
Oh yeah, I guess I would need the GSR ECU for vtec wouldn't I?
Honda started OBDII in 96. So the 94 and 95 integras are OBDI. You will need a GSR ECU in order to obviously make it run. Good luck on whatever you do.
