Old 12-03-2005, 07:02 PM
jillian1 jillian1 is offline
Radio/fuse
I can't understand what has happened to my radio..I was driving down the road and it just quit working, cd player , radio and clock..I changed the fuse 3 times and it still is not working..Any suggestions?..Thank you Jill
Old 12-03-2005, 08:56 PM
B33p3r B33p3r is offline
Not being a wise guy...was the fuse bad each time you changed it?
Old 12-03-2005, 09:18 PM
Re: Radio/fuse
Yes..I thought maybe I had some bad fuses even though they were bought new..Still no luck..
Old 12-04-2005, 08:59 PM
Sounds like it's internal to your radio.
Old 12-04-2005, 09:16 PM
Re: Radio/fuse
Thank you for the suggestions..I went back to a few posts and found where someone mentioned resetting the 10D fuse..Tried that and it solved the problem! Horray!!...Now I have my music back..lol
Old 12-05-2005, 04:47 PM
vipergg vipergg is offline
Re: Re: Radio/fuse
Isn't it nice having everything run thru the bcm now.
Old 12-05-2005, 09:14 PM
I thought you said the fuse was bad each time you checked them?.....I hate the BCM too. I wish they would go back to relays or direct wiring!
Old 12-05-2005, 10:28 PM
Re: Radio/fuse
Initially I only changed the radio fuse alone..I didn't realize that the 10D fuse also had to be changed..Here I was trying 4 new fuses for the radio one alone..I'm sure many folks don't realize they have reset both ..The 10D was NOT burned out..It only had to be taken out and then reset ..
