Old 12-03-2005, 06:04 PM
djstifft djstifft is offline
Windshield washer pump/rear side marker
Hello,
my windshield washer pump doesn't work. I checked the fuse and its working (same as the wipers). I bought a new one, installed it and....nothing. I got back to O'Reilly auto parts, they tested the pump and its working. Any ideas what is wrong and how to fix that?
Second problem: My right rear side marker is burned. I wanted to change the pulb, but I couldn't even find how to go through to it! From the trunk I can't go through, from the outside are no screws. Any idea how I can fix that?
Thanks for any help.
Old 12-04-2005, 09:06 AM
stuzman stuzman is offline
Re: Windshield washer pump/rear side marker
Originally Posted by djstifft
Hello,
What year is the car?
Old 12-04-2005, 09:58 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Re: Windshield washer pump/rear side marker
Check your washer fluid hoses, they made be clogged. The light should be accessed behind the trunk carpet, deep inside the fender well.
Old 12-04-2005, 10:11 AM
Re: Re: Re: Windshield washer pump/rear side marker
Thanks for the reply. The hoses are fine, I checked them already. The punp doesn't even make a noise.
I tried to access the light from the trunk inside the fender, but there is no access.
Its a 1995 LeSabre Custom.
Old 12-04-2005, 10:52 AM
Loekee75's Avatar
Next thing I'd check is the windshield washer switch. I believe you checked everything else! As far as the light, my last guess would be checking if its accessable from underneath the car?
Old 12-04-2005, 02:24 PM
Re: Re: Re: Re: Windshield washer pump/rear side marker
I just discovered another fuse only for the switch at the autozone repair manual...isn't mentioned in the users manual...I will check that one out...on my first check, I noticed that somebody had connected the fuses 6A and 8D with a wire, anybody knows for what?
Yes, I will try to access the light from below.
Thanks for all answers.
Old 12-04-2005, 04:06 PM
Loekee75's Avatar
Re: Re: Re: Re: Re: Windshield washer pump/rear side marker
If they jumpered the fuse connector, they either didn't have any new fuses on them and just wired it up that way for a makeshift repair, or there's a short that kept blowing those fuses out that they never got repaired.
