Can some one HELP! my 1999 Beetle's Coolant light keeps coming on! It can go for days and even as long as a week and then it starts coming on while im driving. I have check the coolant level and its fine! I have checked all the fuse and they are fine! I have check all the hoses and they are also fine. I am conveinced that it is the senor, so I have removed it. I THIS A BAD THING????
What else could it be???? Last edited by postal65; 12-07-2005 at 10:12 AM. |
Re: Coolant Light keep coming on
Hi, I think I'm having a similar problem as you are. Mine is a 99, and whenever I turn on the car and start driving, the coolant light beeps 3 times and flashes for about 5 minutes. It goes away, but sometimes it'll come back and beep another three times at me. I have not a clue about cars, but I had my oil changed last week and he says the coolant levels and all other fluid levels are fine. When you took the sensor out, did the problem cease?
Re: Re: Coolant Light keep coming on
It didn't stop the problem the darn thing still beeps! I don't know what else to do. I even put in some of that powder that is for leak and so far it has not beeped in two days. So i don't really know if that has solve the porblem. I do know that for where I can see it does not seem like it may have leaks, but I'm getting a little despret, so I'm will to try anything to make it stop.
vw doesnt make 97 beetle. only 98+
could be the ect (coolant temp sensor) its a blue square 4pin connector on the coolant flange under the oil cap on side of cylinder head. THey most commonly go bad. with the engine running check to see if there is any coolant flowing into the resivour. If there isnt any flow than your water pump is faulty.
ASE Master certified and VW certified. Just here to help all check engine light codes ------> http://www.automotiveforums.com/vbul...d.php?t=328630 |
Your Right it was my Typo. I have a 1999
Thanks, I will check the coolant temp sensor. However how do I check to see if the coolant is flowing? Where do i look? What resivour? |
I just had this same problem , the plastic waterpump impeller was in many pieces in my case. It is driven by the timing belt so prepare for major work.Buy an aftermarket pump with a cast iron impeller and a new timing belt and belt tensioner if you are really rich(I didn't change mine) You need a special tool or circlip pliers (good ones) to reset the tensioner) Get a manual like a Haynes because the job is much better accomplished with pictures and instructions, I was under the car for 7 hours.
