Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-03-2005, 04:17 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
Problem Under Hood Please Help
OMG, I get my car back from a bad accident right... I detail the interior...
Then start it up...
I then hear a whistle thing under the hood, It has many tones... When it idles, however when I push the gas the noise subsides but then when I idle during trafic or at a light I hear a loud whistling noise that sounds like im in some sort of fucking spacecraft...
Does anyone know what this could be?
Where would I take it to get diagnosed and fixed? (what kind of shop)
Old 12-03-2005, 06:02 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Dude...it's a belt. Replace it with an OEM one, and tighten it up good. If that dosn't work, look at the condition of the tensioners. My car has the same problem, I will be fixing it in the spring.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-03-2005, 06:35 PM
Re: Problem Under Hood Please Help
first of all what is a tensioners?
Second of all the noise sounds like that of a TEA KETTLE whistling when hot and steam coming out also there is a clanky sound that follows the noise... Any one else what are your responses?
I will most likly have it checked out tuesday or something...
Old 12-03-2005, 08:36 PM
SmicAA72
Guest
Posts: n/a
Its most likely his fan belt or something. A "tensioner" from the root word tension. As in what keeps a certain tight or looseness on the belt
Old 12-03-2005, 10:51 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Our cars have electric fans.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-03-2005, 11:07 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Re: Problem Under Hood Please Help
LOL.
Did you take the car to a shop? was the accident your fault? Make the insurance co fix that shit.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 12-04-2005, 09:30 PM
gcobb gcobb is offline
Open your hood and see if you can tell what area of the car it's coming from. It sounds like it's something pushing or pulling air or vacuum. If it's coming from the front of your engine where the belts are it's probably going to be something there. But I don't know what your car is, whether it's a turbo or anything.
Then start it up...
Old 12-05-2005, 05:31 AM
The car is a 1996 Mistu. SPYDER Eclipse GS NON TURBO 2.4 L
It is coming from the front of the car, I believe towards the drivers side under the hood.
Old 12-05-2005, 06:02 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Bad compressor (air)?
....It has been a LONG time...I want to move to FL or Japan.....
Old 12-06-2005, 01:55 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
definitely a vacuum leak.
now - 2000 civic
soon - 2002 is300
Old 12-06-2005, 03:25 PM
what is a vacuum leak, how does it affect the car?
that is the rattling sound or the hot tea kettle sound?
Old 12-06-2005, 03:29 PM
a vacuum leak is when one of the underhood components that has vaccum running through it leaks (usually and old rubber hose). Are you nt or turbo? That's why when you give it gas you don't hear the "whistle", cause it's no longer under vaccum
now - 2000 civic
soon - 2002 is300
Old 12-06-2005, 03:35 PM
that is correct I am a NON TURBO.
Does a vacuum leak hurt the engine or any parts? It makes that sound but recently it has subsided and all I hear is what sounds clank noise when Idling only.
Old 12-06-2005, 05:06 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
is it a manual transmission?
Old 12-06-2005, 07:05 PM
I am almost 100% positive it is a belt, because it goes away when you rev the engine to higher rpms. I'm telling you, my car has the EXACT same problem. It's like a really high squeel. Very annoying. Pop the hood and listen for where the sound is coming. I bet it's right above the serpentine belt.
'92 3000gt SL
Zoom Stage 1 Clutch
