Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 12-03-2005, 11:36 AM
duane5 duane5 is offline
Intermittent jerking in acceleration
I have a 96 sonoma(2.2l) 130k and it has recently developed
a severe jerking when accelerating. I have changed plugs, & air filter
so far. I would appreciate some advice regarding the best
approach to repair this as it is intermittent. I would like to know the
most likely cause before radomly replacing items. From researching this and other threads I understand that the problem could be any of the following;
PVC valve, distributor cap, fuel fiter, fuel pump, plug wires, vacumn hoses, MAF, oxygen sensors, fuel injectors or ECM
Am I missing anything obvious ?
What is the best approach in troubleshooting/repairing this problem?
Duane
Old 12-03-2005, 06:11 PM
kraziwulff kraziwulff is offline
Re: Intermittent jerking in acceleration
Duane
Does the catalytic converted seem to be stopping up? I have a 95 and it broke loose inside and had to be replaced. You can also remove it and clean it out. Mine jerked and lost power.
Old 12-03-2005, 06:24 PM
Re: Re: Intermittent jerking in acceleration
Thanks for the response,
I'll keep it in mind,
I replaced the O2 sensor, PCV, Fuel filter and added injector cleaner
today. If that doesnt work I'll take a look at the CAT and thought
I'd try change the plug wires next.
Old 12-26-2005, 10:29 PM
davefio davefio is offline
Re: Re: Re: Intermittent jerking in acceleration
Any luck? I have a 94 with the 2.2 and have the same problem. Some times it runs fine, then suddenly bucks like a bronco. I have replaced the fuel filter, wires, pcv valve, tps, and used injector cleaner, with no luck.
