LT1 into a Tpi car?
I've been thinking bout swapping out my 305tpi for a LT1 i've seen the ls1 conversion but you have to change so much. If i went lt1 what all fuel system and etc. mods would need to be done? What i'm considering is a lt1 turbo or twin turbo in my 91 z28 for drag strip.
Re: LT1 into a Tpi car?
if you have a 350 TPI then I suggest keeping it and just building that up. if you have the 305, than yea, go for the LT1.
As far as I know, you'll need the complete LT1 from the oil pan to the intake manifold, and the PCM. There's also the dakota digital box which allows for the speedometer to operate correctly. I suggest dropping a pm to drvingstorm05, he just recently completed an LT1 swap into his 91-92 RS.
yah i got the 305tpi and i can get a whole LT1 for preety good price would i need the LT1 tranny?
you don't need an lt1 tranny, if you have a t5 then i strongly would recommend you put in an t56 off of an lt1 car. but if you have an automatic, then it doesn't make a difference
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune. |
As for motor mounts,ac,power steering, and fuel system all stay the same? What bout wiring up the LT1?
how do i change the wiring on my 86 camaro tpi to lt1
uhh, remove the tpi wiring then replace it with LT1 wiring.
