Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-03-2005, 10:28 AM
cameryfan92 cameryfan92 is offline
Fuel Fillter Replacement?
Where is the fuel pump fuse locatede to run out eccess fuel before removing fillter. Are there any special tools required for proper replacement or can it be done with normal tools.
Old 12-03-2005, 09:20 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Fuel Fillter Replacement?
Search the FAQ thread for "fuel pump"
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-04-2005, 08:48 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Use a crow foot flare nut wrench for lower bolt and Kroil penetrant first. That's the main sticking point. The lower fitting can be very tight, and conventional flare nut wrenches can flex, but the crow foot design won't.
Old 12-04-2005, 06:18 PM
I need to know where the fuel pump fuse is to drain the fuel rail and lines and unless a crow foot flare nut wrench is just a normal wrench please specify on what one is.
