90 Legend Oil leak
I cant find this leak. It leaks on my exaust manifold and stinks real bad. Facing the timing belt area, it seems to be coming from behind the left cam seal area but i cant see where. Not from the seal itself though. I have the factory manual but dont see what it could be. Thanks anyway guys.
Re: 90 Legend Oil leak
The cam seals do go bad. When or if you've changed the timing belt you should have changes the cam seals. If you're sure it's not them there are plates with rubber seals that sit above the manifolds that I've had to change.
i have the same problem with my acura. i think i know where its comig from, but not sure. i do know that when i make laeft hand turns, that the oil is leaking out but not when i make right hand turns. i am guessing that it is the rubber seals in front o the engin. i can kinda see a spill pattern. if this is the same prblem plaese let me know f youfi it.
thank you. |
