Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-03-2005, 10:54 AM
jaysinreject jaysinreject is offline
Exclamation 96contour will not start
My 96 Contour manual transmission stalled yesterday while driving. When I turn the key, I hear a high pitched whirling sound, but the engine would not start.
Even stranger, when I tried to start it one time, I was giving it some gas, and my foot slipped off the clutch, and the car moved forwards a few inches, but did not actually start running.
Old 12-07-2005, 07:17 PM
ppg960's Avatar
ppg960 ppg960 is offline
Re: 96contour will not start
Your starter is gone. The soloniod is not pushing the gear out of the starter to turn the flywheel.
If the car is in good shape and you want to keep it, buy a new one.
Bosch makes good components as well as Champion.
Old 01-05-2006, 07:58 AM
WilliamBarnesJr. WilliamBarnesJr. is offline
I recently replaced the engine in a 96 contour. Will not start, does the computer need to be reset, and if so how do you reset it?
Old 01-05-2006, 08:19 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Re: 96contour will not start
no, it doesnt.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 01-05-2006, 05:39 PM
ppg960's Avatar
Exclamation Re: Re: 96contour will not start
Look at the simple things.
Do you have spark, fuel, Is it turning over slowly??? etc...
You can reset the computer by taking the negative post off the battery for about 30 seconds.
Try to be more specific about what is happening when you are trying to start the engine.
